The Web filter policy is applied at the profile or device level.
For more information on URL filtering, see url-filter.
web-filter-policy <WEB-FILTER-POLICY-NAME>
| <WEB-FILTER-POLICY-NAME> | Specify the Web filter policy name. If the policy with the specified name does not exist, it is created. |
nx9500-6C8809(config)#web-filter-policy test nx9500-6C8809(config-web-filter-policy-test)#? Content Filter Mode commands: cache-max-recs Configure the maximum number of records in local cache cache-save-interval Configure the time a record is saved in local cache logging Select logging method no Negate a command or set its defaults server-host Configure URL classification server if it is not the adopted controller server-unreachable Permission to access website when classification server is unreachable (default is pass) uncategorized-url Permission to website when server fails to classify the URL request (default is pass) clrscr Clears the display screen commit Commit all changes made in this session do Run commands from Exec mode end End current mode and change to EXEC mode exit End current mode and down to previous mode help Description of the interactive help system revert Revert changes service Service Commands show Show running system information write Write running configuration to memory or terminal nx9500-6C8809(config-web-filter-policy-test)#
| no | Removes an existing Web filter policy |
