relay-agent
      Enables support for DHCP/DHCPv6 relay agent information
         (option 82 and DHCPv6-LDRA) feature on this WLAN. This option is disabled by
         default.
            - Access Points: AP5010, AP310i/e, AP410i/e, AP505i, AP510i, AP510e, AP560i, AP6522, AP6562, AP7161, AP7502,
               AP8533.
            - Service Platforms:
      Syntax
         relay-agent [dhcp-option82|dhcpv6-ldra]
      Parameters
                     | relay-agent |
                     Enables support for the following DHCP and DHCPv6 options: option 82 and
                           Lightweight DHCPv6 Relay Agent (LDRA) respectively. When enabled,
                        this feature allows the DHCP/DHCPv6 relay agent to insert the relay agent
                        information option (option 82, LDRA) in client requests forwarded to the
                        DHCP/DHCPv6 server. This information provides the following:
                           - circuit ID suboption –
                              Provides the SNMP port interface index
                           - remote ID – Provides
                              the controller‘s MAC address
                     | dhcp-option82 |
                     Enables DHCP option 82. DHCP option 82 provides client physical
                        attachment information. This option is disabled by default. |
                     | dhcpv6-ldra |
                     Enables the DHCPv6 relay agent. The LDRA feature allows DHCPv6 messages
                        to be transmitted on existing networks that do not currently support IPv6 or
                        DHCPv6. This option is disabled by default. |
         ap505-13403B(config-wlan-test)#relay-agent dhcp-option82
         ap505-13403B(config-wlan-test)#show context
wlan test
 ssid test
 vlan 1
 bridging-mode local
 encryption-type ccmp
 authentication-type mac
 dynamic-vlan-assignment allowed-vlans 2-4
 protected-mgmt-frames mandatory
 protected-mgmt-frames sa-query attempts 1
 use aaa-policy test
 http-analyze syslog host 10.234.160.4 port 21 proxy-mode through-controller
 controller-assisted-mobility
 opendns device-id 1222222222222356
 dpi metadata http
         nx9500-6C8809(config-wlan-test)#relay-agent dhcpv6-ldra
         nx9500-6C8809(config-wlan-test)#show context
wlan test
 ssid test
 bridging-mode tunnel
 encryption-type none
 authentication-type none
      Related Commands
                     | no (wlan-config-mode) |
                     Disables support for DHCP/DHCPv6 relay agent information (option 82 and
                        DHCPv6-LDRA) feature on this WLAN |
