peer
gre-config-instance
Adds the GRE tunnel‘s end-point peers. A maximum of two peers, representing the tunnel‘s end points, can be added for each GRE tunnel.
- Access Points: AP5010, AP310i/e, AP410i/e, AP505i, AP510i, AP510e, AP560i, AP6522, AP6562, AP7161, AP7502,
AP8533.
- Service Platforms:
peer <1-2> ip <IPv4/IPv6>
Parameters
| peer <1-2>
ip <IPv4/IPv6> |
Configures the
- <1-2> – Specify a
numeric index for each peer to help differentiate the tunnel end
points.
- ip – Specify the IP
address (IPv4/IPv6) of the added GRE peer to serve as a network
address identifier.
- <IPv4/IPv6> – Specify the peer‘s IPv4 or IPv6
address.
rfs4000-229D58(config-device 00-23-68-22-9D-58-gre-tunnel-testGRETunnel)#peer 1
ip 192.168.13.6
rfs4000-229D58(config-device 00-23-68-22-9D-58-gre-tunnel-testGRETunnel)#show context
gre tunnel testGRETunnel
peer 1 ip 192.168.13.6
native tagged
dscp 20
failover interval 200 retry 5
Related Commands
| no |
Removes the GRE tunnel settings based on the parameters passed |
