area <AREA-NAME/STRING-ALIAS> [assignable-power|channel-list]
area <AREA-NAME/STRING-ALIAS> assignable-power [2.4GHz|5GHz|6GHz] [min|max] <1-20>
area <AREA-NAME/STRING-ALIAS> channel-list [2.4GHz|5GHz|6GHz] <CHANNEL-LIST>
area <AREA-NAME/STRING-ALIAS> | Specifies the area name
Note: For more
information on aliases, see alias.
assignable-power [2.4GHz|5GHz|6GHz] | Assigns minimum and maximum transmit power values, in
dBm, to the 2.4 GHz, 5 GHz, and 6GHz Smart RF managed radios within the
specified area. The per-area transmit power values override the generic
transmit power values configured in the Smart-RF policy assignable-power. Select the band:
After selecting the area and band specify the minimum and
maximum transmit power values:
min <1-20> | After selecting the band specify the minimum assignable
transmit power
max <1-20> | After selecting the band specify the maximum assignable
transmit power
Note: As a best
practice, we recommend not to increase the maximum power values for the
2.4 GHz or 5 GHz radios beyond the default 17 dBm, which provides a 3 dBm
margin for the Neighbor Recovery and Coverage Hole Recovery features. If
each radio in the system is operating at a maximum of 20 dBm, the Smart
RF managed radios will be unable to increase their transmit power if a
neighboring AP fails or a coverage hole is detected. Increase the maximum
power value only if the Neighbor Recovery and Coverage Hole Recovery
features are disabled.
Note: For more
channel-list [2.4GHz|5GHZ|6GHZ] <CHANNEL-LIST> |
Selects the channels for the specified area in the 2.4
GHz, 5.0 GHz, or 6.0 GHz band
nx9500-6C8809(config-smart-rf-policy-test)#area test1 assignable-power 2.4GHz min 10 max 15
nx9500-6C8809(config-smart-rf-policy-test)#show context smart-rf-policy test area test1 assignable-power 2.4GHz min 10 max 15 no select-shutdown nx9500-6C8809(config-smart-rf-policy-test)#
nx9500-6C8809(config)#alias string $AREA Ecospace nx9500-6C8809(config)#commit nx9500-6C8809(config-smart-rf-policy-test)#exit
nx9500-6C8809(config-smart-rf-policy-Ecospace)#area $AREA channel-list 5GHz 36,44
nx9500-6C8809(config-smart-rf-policy-Ecospace)#show context smart-rf-policy Ecospace area $AREA channel-list 5GHz 36,44 nx9500-6C8809(config-smart-rf-policy-Ecospace)#
no (smart-rf-policy-config-mode-command) | Removes channel list/power configuration for an area |
