transform-set
crypto-remote-vpn-client commands
Specifies the IPSec Transform set to use with this remote VPN client. A transform set is a combination of security protocols, algorithms, and other settings applied to IPSec protected client traffic.
Syntax
transform-set <IPSEC-XFORM-TAG> {<IPSEC-XFORM-TAG>}
Parameters
transform-set <IPSEC-XFORM-TAG> <IPSEC-XFORM-TAG> Associates an IPSec Transform (should be existing and configured) set with this remote VPN client. You can optionally associate more than one transform set with this remote VPN client configuration. List the transform set tags separated by a space.
Note: To configure a transform-set, use the
crypto > ipsec > transform-set
command in the profile or device configuration mode.
nx9500-6C8809(config-profile-testAP8533-crypto-ikev2-remote-vpn-client)#transform-set TransformSet1
nx9500-6C8809(config-profile-testAP8533-crypto-ikev2-remote-vpn-client)#show
context
 crypto remote-vpn-client
  peer 1 ikev2 ikev2Peer1
