custom-scan
Configures the channel scanning settings when the scan-mode is set to custom-scan
If the mode of scanning is set to Custom-Scan, use this command to configure the channels to be scanned. To set the mode of scanning to custom-scan, use the scan-mode > Custom-Scan command. For more information, see scan-mode.
Syntax
custom-scan channel-frequency <CHANNEL-FREQUENCY> width
[20MHz|40MHz-Bth|40MHz-Lower|40MHz-Upper|80MHz] scan-weight <SCAN-WEIGHT>
Parameters
custom-scan Configures the custom-scan channel frequency, channel width, and scan weight
channel-frequency <CHANNEL-FREQUENCY> Configures the channel frequency. A list of unique channels in the 2.4, 4.9, 5 and 6 GHz band can be collectively or individually enabled for customized channel scans and RSSI reporting.
  • <CHANNEL-FREQUENCY> – Specify a single or multiple, ‘comma-separated‘ channel frequencies.
width [20MHz| 40MHz-Both| 40MHz-Lower| 40MHz-Upper| 80MHz] Configures the channel width. When custom channels are selected for RSSI scans, each selected channel can have its own width defined. Numerous channels have their width fixed at 20MHz, 802.11a radios support 20 and 40 MHz channel widths.
  • 20MHz – Sets the channel width as 20 Mhz
  • 40Mhz-Both – Sets the channel width as 40Mhz-Both
  • 40Mhz-Lowe – Sets the channel width as 40Mhz-Lower
  • 40Mhz-Upper – Sets the channel width as 40Mhz-Upper
  • 80Mhz – Sets the channel width as 80Mhz
scan-weight <SCAN-WEIGHT> Configures the scan-weight (scanning duration) for each of the selected channels. Each selected channel can have its weight prioritized in respect to the amount of time a scan is permitted within the defined RSSI scan interval.
  • <SCAN-WEIGHT> – Specify the scan weightage given to each selected channel.
nx9500-6C8809(config-sensor-policy-test)#custom-scan channel-frequency 2412 width 20MHz scan-weight 1000
nx9500-6C8809(config-sensor-policy-test)#custom-scan channel-frequency 2417 width 20MHz scan-weight 1000
nx9500-6C8809(config-sensor-policy-test)#show context
sensor-policy test
 scan-mode Custom-Scan
Related Commands
no (sensor-policy-config-mode-commands) Removes channels from the channels-to-scan list in case of scan-mode being set to Custom-Scan
