accounting [interim|server|type]
accounting interim interval <60-3600>
accounting server [<1-12>|preference]
accounting server preference [auth-server-host|auth-server-number|none]
accounting server <1-12> [dscp|host|nai-routing|onboard|proxy-mode|retry-timeout-factor| timeout]
accounting server <1-12> [dscp <0-63>|retry-timeout-factor <50-200>]
accounting server <1-12> host <IP/HOSTNAME/HOST-ALIAS> secret [0 <SECRET>|2 <SECRET>|<SECRET>] {port <1-65535>}
accounting server <1-12> nai-routing realm-type [prefix|suffix] realm <REALM-TEXT> {strip}
accounting server <1-12> onboard [centralized-controller|self|controller]
accounting server <1-12> proxy-mode [none|through-centralized-controller|through-controller| through-mint-host <HOSTNAME/MINT-ID>|through-rf-domain-manager]
accounting server <1-12> timeout <1-60> {attempts <1-10>}
accounting type [start-interim-stop|start-stop|stop-only]
interim |
Configures the interim accounting interval. This is the interval at which interim accounting updates are posted to the accounting server. |
interval <60-3000> |
Specify the interim interval from 60 - 3600 seconds. The default is 1800 seconds. |
server |
Configures the RADIUS accounting server‘s settings |
preference |
Configures the accounting server‘s preference mode. Authentication requests are forwarded to an accounting server, from the pool, based on the preference mode selected. |
auth-server-host |
Sets the authentication server as the accounting
server. This is the default setting. This parameter indicates the same server is used for authentication and accounting. The server is identified by its hostname. |
auth-server-number |
server This parameter indicates the same server is used for authentication and accounting. The server is identified by its index number. |
none |
Indicates the accounting server is independent of the authentication server |
server <1-12> |
Configures an accounting server. Up to 12 accounting servers can be
configured.
dscp <0-63> |
Sets the Differentiated Services Code Point (DSCP)value for
Quality of Service (QoS)monitoring. This value is used in
generated RADIUS packets.
retry-timeout-factor <50-200> | Sets the scaling factor for retransmission
timeouts. The timeout at each attempt is a function of this retry-timeout
factor and the attempt number.
If the scaling factor is 100, the interval between two consecutive retries remains the same, irrespective of the number of retries. If the scaling factor is less than 100, the interval between two consecutive retires reduces with subsequent retries. If this scaling factor is greater than 100, the interval between two consecutive retries increases with subsequent retries. |
accounting server <1-12> host <IP/HOSTNAME/HOST-ALIAS> secret [0 <SECRET>|2 <SECRET>| <SECRET>] {port <1-65535>}
server <1-12> | Configures an accounting server. Up to 12 accounting servers can be
configured.
host <IP/HOSTNAME/HOST-ALIAS> | Configures the accounting server‘s hostname IP
address, or host-alias The host alias should be existing and configured. |
secret [0 <SECRET>| 2 <SECRET>| <SECRET>] | Configures a common secret key used to
authenticate with the accounting server
port <1-65535> | Optional. Configures the accounting server‘s UDP
port (the port used to connect to the accounting server)
server <1-12> |
configured.
nai-routing | Enables Network Access Identifier (NAI) routing. This
option is disabled by default. The NAI is a character string in the format of an e-mail address as either user or user@realm but it need not be a valid e-mail address or a fully qualified domain name. AAA servers identify clients using the NAI. The NAI can be used either in a specific or generic form. The specific form, which must contain the user portion and may contain the @realm portion, identifies a single user. Using the generic form allows all users to be configured on a single command line, irrespective of whether the users are within a realm or not. Each user still needs a unique security association, but these associations can be stored on a AAA server. The original purpose of the NAI was to support roaming between dial up ISPs. With NAI, an ISP does not have the accounts for all of its roaming partners in a single RADIUS database. RADIUS servers can proxy requests to remote servers as need be. |
realm-type | Specifies whether the prefix or suffix of the username is used as the match criteria. For example, if the option selected is prefix, the username‘s prefix is matched to the realm. |
[prefix|suffix] |
Select one of the following options:
realm <REALM-TEXT> | Configures the text matched against the username.
Enter the realm name (should not exceed 50 characters). When the RADIUS
accounting server receives a request for a user name, the server references
a table of user names. If the user name is known, the server proxies the
request to the RADIUS server.
strip | Optional. When enabled, strips the realm from the username before forwarding the request to the RADIUS server. This option is disabled by default. |
configured.
onboard |
Selects an onboard server instead of an external host |
centralized-controller | Configures the server on the centralized controller managing the network |
self | Configures the onboard server on a AP, wireless controller, or service platform (where the client is associated) |
controller | Configures local RADIUS server settings |
accounting server <1-12> proxy-mode [none|through-centralized-controller| through-controller|through-mint-host <HOSTNAME/MINT-ID>|through-rf-domain-manager]
configured.
proxy-mode | Configures the mode used to proxy requests. The options are: none, through-controller, and through-rf-domain-manager. |
none | No proxy required. Sends the request directly using the IP address of the device. This is the default setting. |
through-centralized-controller | Proxies requests through the centralized controller that is configuring and managing the network |
through-controller | Proxies requests through the controller (access point, wireless controller, or service platform) configuring the device |
through-mint-host <HOSTNAME/MINT-ID> | Proxies requests through a neighboring MiNT device. Provide the device‘s MiNT ID or hostname. |
through-rf-domain- manager | Proxies requests through the local RF Domain Manager |
configured.
timeout <1-60> | Configures the timeout for each request sent to
the RADIUS server
{attempts<1-10>} | Optional. Specifies the number of attempts made
at transmitting a request before being dropped
type | Configures the type of RADIUS accounting packets sent. The options are: start-interim-stop, start-stop, and stop-only. |
start-interim-stop | Sends accounting-start and accounting-stop messages at the start and end of the session. This option also sends interim accounting updates. |
start-stop | Sends only accounting-start and accounting-stop messages at the start and end of the session. Interim accounting updates are not sent. This is the default setting. |
stop-only | Sends only an accounting-stop message at the end of the session |
nx9500-6C8809(config-aaa-policy-test)#accounting interim interval 65
nx9500-6C8809(config-aaa-policy-test)#accounting server 2 host 172.16.10.10 secret
test1 port 1
nx9500-6C8809(config-aaa-policy-test)#accounting server 2 timeout 2 attempts 2
nx9500-6C8809(config-aaa-policy-test)#accounting type start-stop
nx9500-6C8809(config-aaa-policy-test)#accounting server preference auth-server-number
nx9500-6C8809(config-aaa-policy-test)#show context aaa-policy test accounting server 2 host 172.16.10.10 secret 0 test1 port 1 accounting server 2 timeout 2 attempts 2 accounting interim interval 65 accounting server preference auth-server-number nx9500-6C8809(config-aaa-policy-test)#
no | Removes or resets accounting server parameters |
