By default all event monitoring is disabled.event [ap-anomaly|client-anomaly|enable-all-events|excessive]
event ap-anomaly [ad-hoc-violation|airjack|ap-ssid-broadcast-in-beacon|asleap| impersonation-attack|null-probe-response|transmitting-device-using-invalid-mac| unencrypted-wired-leakage|wireless-bridge]
event client-anomaly [dos-broadcast-deauth|fuzzing-all-zero-macs| fuzzing-invalid-frame-type|fuzzing-invalid-mgmt-frames|fuzzing-invalid-seq-num| identical-src-and-dest-addr|invalid-8021x-frames|netstumbler-generic| non-conforming-data|wellenreiter] {filter-ageout <0-86400>}
event enable-all-events
event excessive [80211-replay-check-failure|aggressive-scanning|auth-server-failures| decryption-failures|dos-assoc-or-auth-flood|dos-eapol-start-storm|dos-unicast-deauth-or-disassoc| eap-flood|eap-nak-flood|frames-from-unassoc-station] {filter-ageout <0-86400>| threshold-client <0-65535>|threshold-radio <0-65535>}
ap-anomaly |
Enables AP anomaly event tracking An AP anomaly event refers to suspicious frames sent by neighboring APs. An administrator enables or disables the filtering of each listed event and sets the thresholds for the generation of event notification and filtering. |
ad-hoc-violation |
Tracks ad-hoc network violations |
airjack |
Tracks AirJack attacks |
ap-ssid-broadcast-in-beacon |
Tracks AP SSID broadcasts in beacon events |
asleap |
Tracks ASLEAP attacks. These attacks break LEAP (Lightweight Extensible Authentication Protocol) passwords |
impersonation-attack |
Tracks impersonation attacks. These are also referred to as spoofing attacks, where the attacker assumes the address of an authorized device. |
null-probe-response |
Tracks null probe response attacks |
transmitting-device-using- invalid-mac |
Tracks the transmitting device using an invalid MAC address |
unencrypted-wired-leakage |
Tracks unencrypted wired leakage |
wireless-bridge |
Tracks WDS (wireless bridge) frames |
event client-anomaly [dos-broadcast-deauth|fuzzing-all-zero-macs|fuzzing-invalid-frame-type| fuzzing-invalid-mgmt-frames|fuzzing-invalid-seq-num|identical-src-and-dest-addr|invalid-8021x-frames| netstumbler-generic|non-conforming-data|wellenreiter] {filter-ageout <0-86400>}
client-anomaly |
Enables client anomaly event tracking These are suspicious events performed by wireless clients that compromising the security of the network. An administrator can enable or disable the filtering of each listed event and set the thresholds required for the generation of the event notification and filtering action applied. |
dos-broadcast-deauth |
Tracks DoS broadcast deauthentication events |
fuzzing-all-zero-macs |
Tracks Fuzzing: All zero MAC addresses observed |
fuzzing-invalid-frame-type |
Tracks Fuzzing: Invalid frame type detected |
fuzzing-invalid-mgmt-frames |
Tracks Fuzzing: Invalid management frame detected |
fuzzing-invalid-seq-num |
Tracks Fuzzing: Invalid sequence number detected |
identical-src-and-dest-addr |
Tracks identical source and destination addresses detection |
invalid-8021x-frames |
Tracks Fuzzing: Invalid 802.1x frames detected |
netstumbler-generic |
Tracks Netstumbler (v3.2.0, 3.2.3, 3.3.0) events |
non-changing-wep-iv |
Tracks unchanging WEP IV events |
non-conforming-data |
Tracks non conforming data packets |
wellenreiter |
Tracks Wellenreiter events |
filter-ageout <0-86400> |
The following keywords are common to all of the above client anomaly events:
Note: For each violation define a filter time in seconds, which determines
how long the packets (received from an attacking device) are ignored once
a violation has been triggered. Ignoring frames from an attacking device
minimizes the effectiveness of the attack and the impact to the site
until permanent mitigation can be performed.
The filter ageout value is applicable across the entire RF Domain using this WIPS policy. If an MU is detected performing an attack and is filtered by one of the APs, the information is passed on to all APs and controllers within the RF Domain through the domain manager. Consequently the MU is filtered, for the specified period of time, across all devices. |
enable-all-events |
Enables tracking of all intrusion events (client anomaly and excessive events) |
event excessive [80211-replay-check-failure|aggressive-scanning| auth-server-failures|decryption-failures|dos-assoc-or-auth-flood|dos-eapol-start-storm| dos-unicast-deauth-or-disassoc|eap-flood|eap-nak-flood|frames-from-unassoc-station] {filter-ageout [<0-86400>]|threshold-client [<0-5535>]|threshold-radio <0-65535>}
excessive |
Enables the tracking of excessive events. Excessive events are actions performed continuously and repetitively. These events can impact the performance of the controller managed network. DoS attacks come under this category. |
80211-replay-check-failure |
Tracks 802.11replay check failure |
aggressive-scanning |
Tracks aggressive scanning events |
auth-server-failures |
Tracks failures reported by authentication servers |
decryption-failures |
Tracks decryption failures |
dos-assoc-or-auth-flood |
Tracks DoS association or authentication floods |
dos-eapol-start-storm |
Tracks DoS EAPOL start storms |
dos-unicast-deauth-or- disassoc |
Tracks DoS dissociation or deauthentication floods |
eap-flood |
Tracks EAP floods |
eap-nak-flood |
Tracks EAP NAK floods |
frames-from-unassoc-station |
Tracks frames from unassociated clients |
The following keywords are common to all excessive events:
Note: This value is applicable across the RF Domain. If a client is detected
is passed to the domain controller. The domain controller then propagates
this information to all APs and wireless controllers in the RF
Domain.
threshold-client <0-65535> |
threshold-radio <0-65535> |
nx9500-6C8809(config-wips-policy-test)#event excessive 80211-replay-check-failure
filter-ageout 9 threshold-client 8 threshold-radio 99
nx9500-6C8809(config-wips-policy-test)#show context wips-policy test event excessive 80211-replay-check-failure threshold-client 10 threshold-radio 99 filter-ageout 9 event client-anomaly wellenreiter filter-ageout 99 ap-detection-ageout 50 ap-detection-wait-time 15 nx9500-6C8809(config-wips-policy-test)#
no (wips-policy-config-mode-command) |
Disables WIPS policy events tracking |
