Displays a L2TPv3 session information
This command is not available in the USER EXEC mode.show l2tpv3 {on|statistics|tunnel|tunnel-summary}
         show l2tpv3 {on <DEVICE-NAME>}
         show l2tpv3 statistics {on <DEVICE-NAME>)}
         show l2tpv3 {tunnel <L2TPv3-TUNNEL-NAME>} {session <L2TPv3-SESSION-NAME>} {on <DEVICE-NAME>)}
         show l2tpv3 {tunnel-summary} {down|on|up}
         show l2tpv3 {tunnel-summary} {on <DEVICE-NAME>}
         show l2tpv3 {tunnel-summary} {down|up} {on <DEVICE-NAME>}
         | l2tpv3 {on <DEVICE-NAME>} | Displays L2TPv3 tunnel and session details or summary
                         show l2tpv3 statistics  |
                         Displays L2TPv3 Tunnel and session statistics. It displays the information, such as the number of packets transmitted and received, the rate of transmission, number of packets dropped, etc.  |
                         on <DEVICE-NAME>  |
                         Optional. Executes the command on a specified device
 Note:
                     If you do not specify a device name, the system executes the command on the logged device.  |
show l2tpv3 {tunnel <L2TPv3-TUNNEL-NAME>} {session <L2TPv3-SESSION-NAME>} {(on <DEVICE-NAME>)}
         | l2tpv3 | Displays L2TPv3 tunnel and session details or summary |
| tunnel <L2TPv3-TUNNEL- NAME> | Optional. Displays a specified L2TPv3 tunnel information
| session <L2TPv3-SESSION- NAME> | Optional. Displays a specified L2TPv3 tunnel session information
| on <DEVICE-NAME> | The following keyword is recursive and common to the ‘session
                        <L2TPv3-SESSION-NAME>' parameter.
         | l2tpv3 | Displays L2TPv3 tunnel and session details or summary Note: For an L2TPv3 tunnel over
                           Auto IPSec, the tunnel status is displayed as: Established (secured by
                           ipsec)
| tunnel-summary {on <DEVICE-NAME>} | Optional. Displays L2TPv3 tunnel summary
| tunnel-summary | Optional. Displays L2TPv3 tunnel summary, based on the parameters passed |
| down | Optional. Displays un-established tunnels summary |
| up | Optional. Displays established tunnels summary |
| on <DEVICE-NAME> | The following keyword is common to the ‘down' and ‘up' parameters:
ap7532-11E6C4#show l2tpv3 tunnel-summary --------------------------------------------------------------------------------------- Sl No Tunnel Name Tunnel State Estd/Total Sessions Encapsulation Protocol --------------------------------------------------------------------------------------- 1 testTunnel Established (secured by ipsec) 1/1 IP Total Number of Tunnels 1 ap7532-11E6C4#
Tunnel Name : testTunnel
  Control connection id : 2238970979
  Peer Address : 30.1.1.1
  Local Address : 30.1.1.30
  Encapsulation Protocol : IP
  MTU : 1460
  Peer Host Name : rfss
  Peer Vendor Name : Example Company
  Peer Control Connection ID : 322606389
  Tunnel State : Established (secured by ipsec)
  Establishment Criteria : always
  Sequence number of the next msg to the peer : 29
  Expected sequence number of the next msg from the peer :42
  Sequence number of the next msg expected by the peer : 29
  Retransmission count : 0
  Reconnection count : 0
  Uptime : 0 days 1 hours 2 minutes 47 seconds
  Session Name : session1
    VLANs : 30
    Pseudo Wire Type : Ethernet_VLAN
    Serial number for the session : 6
    Local Session ID : 129538998
    Remote Session ID : 8151374
    Size of local cookie (0, 4 or 8 bytes) : 0
    First word of local cookie : 0
    Second word of local cookie : 0
    Size of remote cookie (0, 4 or 8 bytes) : 0
    First word of remote cookie : 0
    Second word of remote cookie : 0
    Session state : Established
    Remote End ID : 444
    Trunk Session : 1
    Native VLAN tagged : Enabled
    Native VLAN ID : 0
    Number of packets received : 0
    Number of bytes received : 0
    Number of packets sent : 0
    Number of bytes sent : 0
    Number of packets dropped : 0
ap7532-11E6C4#
