crypto-remote-vpn-client commands
Configures IKEv2 peers and assigns them priorities for utilization with remote VPN client connections. A maximum of three (3) peers can be added to support redundancy.
IKEv2 uses an initial handshake in which VPN peers negotiate cryptographic algorithms, mutually authenticate, and establish a session key, creating an IKE-SA. Additionally, a first IPSec SA is established during the initial SA creation. All IKEv2 messages are request/response pairs. It is the responsibility of the side sending the request to retransmit if it does not receive a timely response.
peer <1-3> ikev2 <IKEV2-PEER-NAME>
| peer <1-3> | Adds a IKEv2
peer. You can add maximum of three (3) peers to achieve redundancy.
| ikev2 <IKEV2-PEER-NAME> | Specify the
IKEv2 peer‘s name. Note: The peer should be existing and configured. To configure an
IKEv2 peer use the crypto > ikev2 > peer > <IKEv2-PEER-NAME>
command.
nx9500-6C8809(config-profile-testAP8533-crypto-ikev2-remote-vpn-client)#peer 1 ikev2 ikev2Peer1 nx9500-6C8809(config-profile-testAP8533-crypto-ikev2-remote-vpn-client)#peer 2 ikev2 ikev2Peer2 nx9500-6C8809(config-profile-testAP8533-crypto-ikev2-remote-vpn-client)#show context crypto remote-vpn-client peer 1 ikev2 ikev2Peer1 peer 2 ikev2 ikev2Peer2 nx9500-6C8809(config-profile-testAP8533-crypto-ikev2-remote-vpn-client)#
