no [enable|mandatory app stats app-group <APPLICATION-GROUP-NAME>|server host [<IPv4>|<HOST-NAME>|<IPv6>]]]
no <PARAMETERS>
no <PARAMETERS> | Removes NSight policy settings based on the parameters passed |
The following example shows the NSight policy ‘test2‘ settings before the ‘no‘ command is executed:
nx9510-6C8A5C(config-nsight-policy-test2)#show context nsight-policy test2 server host 172.22.0.153 http nx9510-6C8A5C(config-nsight-policy-test2)#
nx9510-6C8A5C(config-nsight-policy-test2)#no server host 172.22.0.153
The following example shows the NSight policy ‘test2‘ settings after the ‘no‘ command is executed:
nx9510-6C8A5C(config-nsight-policy-test2)#show context nsight-policy test2 nx9510-6C8A5C(config-nsight-policy-test2)#
