mint-policy
      Configures the global MiNT policy and
         enters its configuration mode
            - Access Points: AP5010, AP310i/e, AP410i/e, AP505i, AP510i, AP510e, AP560i, AP6522, AP6562, AP7161, AP7502,
               AP8533.
            - Service Platforms:
      Syntax
         mint-policy global-default
      Parameters
                     | global-default |
                     Configures the global default MiNT policy |
         nx9500-6C8809(config)#mint-policy global-default
nx9500-6C8809(config-mint-policy-global-default)#?
Mint Policy Mode commands:
  level    Mint routing level
  lsp      LSP
  mtu      Configure the global Mint MTU
  no       Negate a command or set its defaults
  router   Mint router
  udp      Configure mint UDP/IP encapsulation
  clrscr   Clears the display screen
  commit   Commit all changes made in this session
  do       Run commands from Exec mode
  end      End current mode and change to EXEC mode
  exit     End current mode and down to previous mode
  help     Description of the interactive help system
  revert   Revert changes
  service  Service Commands
  show     Show running system information
  write    Write running configuration to memory or terminal
For more information on MiNT policy configuration, see
MiNT Policy.
