Selects the encryption type for this user-defined role. Encryption ensures privacy between Access Points and wireless clients. There are various modes of encrypting communication on a WLAN, such as CCMP (Counter-model CBC-MAC Protocol), WEP (Wired Equivalent Privacy), keyguard, TKIP (Temporal Key Integrity Protocol), etc.
encryption-type [any|eq|neq]
encryption-type any
encryption-type [eq|neq] [ccmp|keyguard|none|tkip|wep128|wep64] (ccmp|keyguard|none|tkip|tkip-ccmp|wep128|wep64)}
encryption-type any
                         any  |
                     The encryption type can be any one of the listed options (ccmp|keyguard|tkip|wep128|wep64). This is the default setting. |
                         eq [ccmp|keyguard|none| |wep128|wep64]  |
                         The role is applied only if the encryption type equals to one of the following options:
 Note: These parameters are recursive, and you can configure more than one
                         neq [ccmp|keyguard|none| wep128|wep64]  |
                         The role is applied only if encryption type is not equal to any of the following options:
                           ‘not equal to‘ encryption type for this user-defined role.
nx9500-6C8809(config-role-policy-test-user-role-testing)#encryption-type eq wep128
         nx9500-6C8809(config-role-policy-test-user-role-testing)#show context user-role testing precedence 10 authentication-type eq kerberos encryption-type eq wep128 ap-location contains office captive-portal authentication-state pre-login city exact SanJose company exact ExampleCompany country exact America department exact TnV emailid exact testing@examplecompany.com employeeid contains TnVTest1 nx9500-6C8809(config-role-policy-test-user-role-testing)#
| no |
                         Removes the encryption type configured for this user-defined role  |
