timers (bgp-neighbor-config)
Configures this BGP neighbor‘s keepalive
and holdtime durations
The keepalive and
holdtime settings configured at the neighbor level override those configured on the BGP
router.
- Service Platforms — NX9500, NX9600
Syntax
timers [<0-65535> <0-65535>|connect <0-65535>]
Parameters
timers <0-65535> <0-65535> |
Sets the keepalive and holdtime intervals
- <0-65535> – Specifies the keepalive interval from 0 - 65535 seconds. It is
the interval, in seconds, between two successive keepalive packets exchanged
with this neighbor to keep the TCP connection alive.
- <0-65535> – Specifies the holdtime interval from 0 - 65535. This is the
time this neighbor will wait without receiving a keepalive packet from its
neighbor before declaring it dead. If the time since the last keepalive
packet received (from its neighbor) exceeds the value set here, the neighbor
is declared dead.
timers connect <0-65535> |
Sets the BGP connect time. This is the interval, in
seconds, after which BGP tries to connect to a dead peer.
- <0-65535> – Specify a value from 1 - 65535 seconds.
nx9500-6C8809(config-profile testNX9000-router-bgp-neighbor-192.168.13.99)#timers 20 40
nx9500-6C8809(config-profile testNX9000-router-bgp-neighbor-192.168.13.99)#timers connect 20
nx9500-6C8809(config-profile testNX9000-router-bgp-neighbor-192.168.13.99)#show context
bgp neighbor 192.168.13.99
remote-as 100
advertisement-interval 100
peer-group eBGPPeerGrp1
port 21
strict-capability-match
timers connect 20
timers 20 40
allowas-in 10
attribute-unchanged as-path
capability orf prefix-list both
default-originate
description neighbor "This neighbor is an external AS neighbor"
disable-connected-check
dont-capability-negotiate
ebgp-multihop 20
enforce-multihop
local-as 20 no-prepend
maximum-prefix 400 50 warning-only
next-hop-self
override-capability
passive
password neighbor eBGPneighbor@300
remove-private-as
route-server-client
send-community both
