This section describes how to revert the mode of operation of an AP operating in the 'Centralized' mode.
If the AP boots up in the 'Centralized' mode, use the following command to reset the mode of operation to factory-default setting (that is, not specified). Issue the command on the AP.
#cset factoryDefault deep
When you issue the above command, the AP reboots and moves into the discovery mode, where it tries to discover its mode of operation.
To reset the mode of operation to Distributed, issue the following command in the AP's configuration context:
#cset personality distributed
The AP to controller adoption is lost, the AP reboots and moves into adopter discovery mode.
