radius-user-pool-policy
Configures a RADIUS user pool and enters its configuration mode
- Access Points: AP5010, AP310i/e, AP410i/e, AP505i, AP510i, AP510e, AP560i, AP6522, AP6562, AP7161, AP7502,
AP8533.
- Service Platforms:
Syntax
radius-user-pool-policy <RADIUS-USER-POOL-NAME>
Parameters
<RADIUS-USER-POOL-POLICY-NAME> |
Specify the RADIUS user pool policy name. If a policy with the specified
name does not exist, it is created. |
nx9500-6C8809(config)#radius-user-pool-policy testRadiusUserPool
nx9500-6C8809(config-radius-user-pool-testRadiusUserPool)#?
Radius User Pool Mode commands:
duration Set a guest user's access duration
no Negate a command or set its defaults
user Radius user configuration
clrscr Clears the display screen
commit Commit all changes made in this session
do Run commands from Exec mode
end End current mode and change to EXEC mode
exit End current mode and down to previous mode
help Description of the interactive help system
revert Revert changes
service Service Commands
show Show running system information
write Write running configuration to memory or terminal
vnx9500-6C8809(config-radius-user-pool-testRadiusUserPool)#
Related Commands
no
Removes an existing RADIUS user pool policy |
For more information on RADIUS user
group commands, see
RADIUS Policy.
