The BLE data export policy provides the external, third-party server‘s REST URL. After configuring the policy apply it on an RF Domain. Once applied, BLE-enabled, WiNG APs, within the domain, sense BLE iBeacon and Eddystone beacons from other BLE-enabled devices and forward device data to the specified third-party server. This data is forwarded in the JASON format.
Before enabling BLE data export, ensure that the APs‘ Bluetooth radio is active and the mode is set to ‘le-sensor‘. For more information on configuring the Bluetooth settings on the AP‘s profile/device context, see interface-config-bluetooth-instance.
use the BLE data export policy. For more information, see use (rf-domain-config-mode).
use a sensor policy to define the interval at which data is forwarded. For more information, see use (rf-domain-config-mode).
ble-data-export-policy <POLICY-NAME>
| <POLICY-NAME> | Specify the policy name. If a BLE data export policy with the
specified name does not exist, it is created. Note: The name should
not exceed 32 characters in length.
NOC-NX9500(config)#ble-data-export-policy test NOC-NX9500(config-ble-data-export-policy-test)#? Ble Data Export Policy Mode commands: no Negate a command or set its defaults rest Configure the url to send the real time RSSI feed to clrscr Clears the display screen commit Commit all changes made in this session do Run commands from Exec mode end End current mode and change to EXEC mode exit End current mode and down to previous mode help Description of the interactive help system revert Revert changes service Service Commands show Show running system information write Write running configuration to memory or terminal NOC-NX9500(config-ble-data-export-policy-test)#
| no | Removes an existing BLE data export policy |
