privilege-mode-password <PASSWORD/HASHED-STRING-ALIAS-NAME>
privilege-mode-password | Configures the password required to enter the privilege configuration mode. When configured, users are prompted to provide the password when enabling the privilege configuration mode. |
<PASSWORD/HASHED-STRING-ALIAS-NAME> | Enter the password as a clear text, or provide a
hashed-string alias. Enter the password as a clear text,
or provide a hashed-string alias. If using a
hashed-string alias, ensure that the alias is existing
and configured. Note: The
clear text password is saved and displayed as a
hashed string. Hashing is a means of establishing the
integrity of transmitted messages. Before
transmission, a hash of the message is generated,
encrypted and sent along with the message. At the
receiving end, the message and the hash are both
decrypted, and another hash is generated from the
received message. The two hashes are compared. If
both are identical the message is considered to have
been transmitted intact.
Note: For
more information on configuring a hashed-string
alias, see alias.
The following example shows the privilege mode password being configured as a hashed string:
nx9500-6C8809(config-management-policy-test)#privilege-mode-password 1 2e9f038ac2ed27f919ed5a4dceb3d30e32f356f2ceff6fbf26a153d0339c734f
nx9500-6C8809(config-management-policy-test)#show context management-policy test http server no ssh privilege-mode-password 1 2e9f038ac2ed27f919ed5a4dceb3d30e32f356f2ceff6fbf26a153d0339c734f nx9500-6C8809(config-management-policy-test)#
Follow the steps below to configure a hashed-string alias and use it as a privilege mode password:
nx9500-6C8809(config)#alias hashed-string $PriMode Test12345
nx9500-6C8809(config)#show context | include alias alias vlan $BLR-01 1 alias string $IN-Blr-EcoSpace-Floor-4 IBEF4 alias encrypted-string $READ 0 public alias encrypted-string $WRITE 0 private alias hashed-string $PriMode 1 faffdde27cb49ad634ea20df4f7c8ef2685894d10ffcb1b2efba054112ecfc75 nx9500-6C8809(config)#
nx9500-6C8809(config-management-policy-default)#privilege-mode-password $PrivMode
nx9500-6C8809(config-management-policy-default)#show context management-policy default https server rest-server ssh user admin password 1 ad4d8797f007444ccdda3788b9ee0e8b46f3facb4308e045239eb7771e127ed5 role superuser access all snmp-server community 0 $WRITE rw snmp-server community 0 $READ ro snmp-server user snmptrap v3 encrypted des auth md5 2 yqr96yyVzmD4ZbU2I7Eh/QAAAAjWNKa4KXF95pruUCSnhOiT snmp-server user snmpmanager v3 encrypted des auth md5 2 NOf8+2+AY2r4ZbU2I7Eh/QAAAAgc0l8ahJYo3AjHo9wXzYGo t5 snmp-server community public ro 192.168.0.1 t5 snmp-server community private rw 192.168.0.1 privilege-mode-password $PriMode nx9500-6C8809(config-management-policy-default)#
nx9500-6C8809 login: admin Password: Feb 07 14:40:47 2017: %AUTH-6-INFO: login[28768]: user 'admin' on 'ttyS0' from 'Console' logged in Feb 07 14:40:47 2017: nx9500-6C8809 : %SYSTEM-5-LOGIN: Successfully logged in user 'admin' with privilege 'superuser' from 'ttyS0' nx9500-6C8809>en Password:
no (management-policy) | Removes the configured CLI privilege mode access password |
