aggregate (bgp-router-config)
Creates and configures an aggregate address entry in the BGP database
Syntax
aggregate-address <IP/M> {as-set {summary-only}|summary-only}
Parameters
aggregate-address <IP/M> Specify the aggregate IP address and mask
as-set {summary-only} Optional. Summarizes the AS_PATH attributes of the individual routes aggregated
  • summary-only – Optional. Filters more specific routes from updates
nx9500-6C8809(config-device B4-C7-99-6C-88-09-router-bgp)#aggregate-address 192.168.13.10/32 as-set summary-only
nx9500-6C8809(config-device B4-C7-99-6C-88-09-router-bgp)#show context
 router bgp
  bgp enable
  asn 1
   bgp neighbor 192.168.13.199
   remote-as 1
   use route-map UnSupMap_01 in
  bgp neighbor 192.168.13.99
   remote-as 199
   timers connect 10
   timers 20 40
   maximum-prefix 9999 80 restart 50
  bgp neighbor 1.1.1.1
   remote-as 2
   timers connect 10
   timers 20 40
   maximum-prefix 1000000
  bgp-route-limit num-routes 10 reset-time 360
Related Commands
no (bgp-router-config) Removes the aggregate address entry
