The following updates have been made in Revision AB of this Guide.
| Updates | Description |
| gre | The devices that support GRE Tunneling and the Maximum GRE Tunnels Supported have been corrected. |
The following updates have been made in Revision AA of this Guide.
| Update | Description |
| Hardware descriptions and specifications contained in this chapter have been relocated to the Appendices in this Guide. | |
| Log in to the WiNG Controller | New procedure |
| Discovery of available bonjour services can be restricted to service VLANs | |
| customize | Added 6 GHz radio and bridge options in show-wireless-radio rf-mode command |
| radio-resource-measurement |
| Method used to enable and access the Flash user interface on a device has changed | |
| nova (management-policy) | Updated and corrected NOVA UI access instructions |
| gre | Added support for up to 1000 tunnels |
| data-rates | Added 6 GHz option for the data-rates command in the interface-config-radio-instance. |
| rts-threshold | Beginning in WiNG 7.9.1, for optimal performance, the recommended rts-threshold value to use is 2347. |
| ip | Updated default-gateway static-route and dhcp-client priority setting value range from <1 - 1800> to <1 - 8000> |
| data-rates (meshpoint-config) | Corrections and updates made |
