interface-config-radio-instance
Enables 802.11k radio resource measurement. When enabled, the radio station sends channel and neighbor reports.
The IEEE 802.11 Task Group k defined a set of specifications regarding radio resource measurements. These specifications specify the radio resources to be measured and the mechanism used to communicate measurement requests and results.
radio-resource-measurement [attenuation-threshold <1-199>|max-entries <1-12>]
| radio-resource-measurement | Enables 802.11k radio resource measurement on the radio |
| attenuation-threshold <1-199> | Configures the
                        neighbor attenuation threshold, considered when generating channel and
                        neighbor reports
| max-entries <1-12> | Configures the
                        maximum number of entries to include in channel and neighbor reports
ap505-133E1C(config-profile-testap505-if-radio2)##radio-resource-measurement attenuation-threshold 150 ap505-133E1C(config-profile-testap505-if-radio2)#radio-resource-measurement max-entries 10 ap505-133E1C(config-profile-testap505-if-radio2)#show context interface radio2 mesh client beacon period 50 antenna-elevation 5.0 antenna-gain 12.0 off-channel-scan aggregation ampdu tx-only association-list global test aeroscout forward ip 1.23.4.56 port 300 antenna-mode 2x2 antenna-diversity radio-resource-measurement max-entries 10 radio-resource-measurement attenuation-threshold 150 assoc-response rssi-threshold -128 bridge ssid test mu-mimo ldpc lock-rf-mode fallback-channel 104 ap505-133E1C(config-profile-testap505-if-radio2)#
| no (radio-interface-config-command) | Disables 802.11k radio resource measurement support |
