Creating a DHCP Server Policy
The DHCP server policy defines the parameters required to run a DHCP server on the wireless controller and assign IP addresses automatically to devices that associate. Configuring DHCP enables the reuse of a limited set of IP addresses.
To create a DHCP server policy, in the wireless controller‘s global configuration mode, execute the following command:
rfs4000-37FABE(config)#dhcp-server-policy <DHCP-SERVER-POLICY-NAME>
rfs4000(config)#dhcp-server-policy DHCP_POLICY_UseCase1
rfs4000(config-dhcp-policy-DHCP_POLICY_UseCase1)#
The following table displays how IP addresses are used.
Table: IP Address Usage
IP Range
Usage
172.16.11.1 till 172.16.11.10
Reserved for devices that require a static IP address
172.16.11.11 till 172.16.11.200
Range of IP addresses that can be assigned using the DHCP server.
172.16.11.201 till 172.16.11.254
In the table, the IP address range of 172.16.11.11 to 172.16.11.200 is available using the DHCP server. To configure the DHCP server:
rfs4000(config-dhcp-policy-DHCP_POLICY_UseCase1)#dhcp-pool DHCP_POOL_USECASE1_01
rfs4000(config-dhcp-policy-DHCP_POLICY_UseCase1-pool-DHCP_POOL_USECASE1_01)#
  1. Configure the address range as follows:
    rfs4000(config-dhcp-policy-DHCP_POLICY_UseCase1-pool-DHCP_POOL_USECASE1_01)#address range 172.16.11.11 172.16.11.200
  2. Configure the IP pool used with a network segment. This starts the DHCP server on the specified interface.
    rfs4000(config-dhcp-policy-DHCP_POLICY_UseCase1-pool-DHCP_POOL_USECASE1_01)#network 172.16.11.0/24
    rfs4000(config-dhcp-policy-DHCP_POLICY_UseCase1-pool-DHCP_POOL_USECASE1_01)#exit
    rfs4000(config-dhcp-policy-DHCP_POLICY_UseCase1)#exit
    rfs4000(config)#commit write
  3. Configure the RFS 4000 to use the DHCP Policy. For the DHCP to work, apply the policy to the wireless controller, as shown in the following example:
    rfs4000-37FABE(config)#self
    rfs4000-37FABE(config-device-03-14-28-57-14-28)#use dhcp-server-policy DHCP_POLICY_UseCase1
    rfs4000-37FABE(config-device-03-14-28-57-14-28)#commit write
    rfs4000-37FABE(config-device-03-14-28-57-14-28)#exit
