Backs up captive-portal and/or NSight database to a specified location and file. When applied to devices, this profile will enable the back up of the specified database. This command also enables you to configures a low-disk-space threshold value.
These parameters can also be configured in the device configuration context of the NX9500, NX9600 series service platforms.
database [backup|low-disk-space-threshold]
database backup database [captive-portal|nsight] <URL>
database low-disk-space-threshold <10-50>
| database backup database [captive-portal| nsight] | Backs up captive
portal and/or NSight database to a specified location and file. Select the
database to backup.
After specifying the database type, configure the destination location and file name. |
| <URL> | Configures the
destination location. The database is backed up at the specified location.
Specify the location URL in one of the following formats: ftp://<user>:<passwd>@<hostname|IP>[:port]/path/file.tar.gz sftp://<user>:<passwd>@<hostname|IP>[:port]/path/file.tar.gz tftp://<hostname|IP>[:port]/path |
| database low-disk-space-threshold <10-50> | Configures the
low disk space threshold for syslog warning. Once the threshold value
configured here is reached a syslog warning is sent.
nx9500-6C8809(config-profile-testNX9500)#database backup database nsight ftp://anonymous:anonymous@192.168.13.10/backups/nsight/nsight.tar.gz
| no | Removes database backup configurations |
