handoff-count
Specifies the number of times a client can exceed the specified handoff-threshold value before an action is invoked
Syntax
handoff-count <1-10>
Parameters
  • <1-10> – Specify a value from 1 - 10. The default is 3.
If the client‘s RSSI increases beyond the set handoff-threshold, it is removed from the queue for monitoring and action invocation.
nx9500-6C8809(config-roaming-assist-policy-test)#handoff-count 5
nx9500-6C8809(config-roaming-assist-policy-test)#show context
roaming-assist-policy test
 aggressiveness medium-high
 handoff-count 5
 detection-threshold -90
 action log
 disassoc-time 7
Related Commands
no Reverts the configured handoff-count to default
