This section documents the IKEV2 remote VPN client configuration settings. Use this command to define the server resources used to secure (authenticate) a remote VPN connection with a target peer.
Use the profile-config instance to configure remote VPN client settings. To navigate to the remote-vpn-client configuration instance, use the following commands:
<DEVICE>(config)#profile <DEVICE-TYPE> <PROFILE-NAME> <DEVICE>(config-profile-<PROFILE-NAME>)#crypto remote-vpn-client <DEVICE>(config-profile-<PROFILE-NAME>-crypto-ikev2-remote-vpn-client)#
To configure remote VPN client settings on a device, on the device‘s configuration mode, use the crypto > remote-vpn-client
command. For example:
nx9500-6C8809(config-device-B4-C7-99-6C-88-09)#crypto remote-vpn-client
The following configuration enables a access point to adopt to a controller over the remote VPN link:
nx9500-6C8809(config-profile-testNX9500)#controller host <HOST-IP>
remote-vpn-clientnx9500-6C8809(config-device-B4-C7-99-6C-88-09)#controller host <HOST-IP>
remote-vpn-clientnx9500-6C8809(config)#profile ap8533 testAP8533 nx9500-6C8809(config-profile-testAP8533)# nx9500-6C8809(config-profile-testAP8533)#crypto remote-vpn-client nx9500-6C8809(config-profile-testAP8533-crypto-ikev2-remote-vpn-client)#? Crypto IKEV2 Remote Vpn Client Config commands: dhcp-peer Configure parameters for peers received via DHCP option no Negate a command or set its defaults peer Add a remote peer shutdown Disable remote vpn client transform-set Specify IPSec transform to use clrscr Clears the display screen commit Commit all changes made in this session do Run commands from Exec mode end End current mode and change to EXEC mode exit End current mode and down to previous mode help Description of the interactive help system revert Revert changes service Service Commands show Show running system information write Write running configuration to memory or terminal nx9500-6C8809(config-profile-testAP8533-crypto-ikev2-remote-vpn-client)#
The following table summarizes crypto remote VPN client configuration mode commands:
| Command | Description |
| dhcp-peer | Configures DHCP peer‘s local ID and authentication settings |
| peer | Adds a remote IKEv2 peer |
| shutdown | Disables the remote VPN client |
| transform-set | Associates an existing IPSec transform set with this remote VPN client |
| no | Removes the remote VPN client settings |
