exit
      The exit command works differently in
         the User Exec, Priv Exec, and Global Config modes. In the Global Config mode, it ends the
         current mode and moves to the previous mode, which is Priv Exec mode. The prompt changes
         from (config)# to #. When used in the Priv Exec and
         User Exec modes, the exit command ends the current session, and connection to the terminal
         device is terminated. If the current session has changes that have not been committed, the
         system will prompt you to either do a commit or a revert before terminating the
         session.
            - Access Points: AP5010, AP310i/e, AP410i/e, AP505i, AP510i, AP510e, AP560i, AP6522, AP6562, AP7161, AP7502,
               AP8533.
            - Service Platforms:
         nx9500-6C8809(config)#exit
nx9500-6C8809#
