traceroute6
Traces the route to a specified IPv6 destination
This command and its syntax is common to both the User Executable and Privilege Executable configuration modes.
Syntax
traceroute6 <LINE>
Parameters
traceroute6 <LINE>
traceroute6 <LINE> Traces the route to a destination IPv6 address or hostname
  • <LINE> – Specify the destination IPv6 address or hostname.
nx9500-6C88097#traceroute6 2001:10:10:10:10:10:10:2
traceroute to 2001:10:10:10:10:10:10:2 (2001:10:10:10:10:10:10:2) from 2001:10:10:10:10:10:10:1, 30 hops max, 16 byte packets
 1  2001:10:10:10:10:10:10:2 (2001:10:10:10:10:10:10:2)  0.622 ms  0.497 ms  0.531 ms
nx9500-6C8809#
