update (dhcpv4-pool-config)
Controls the use of the DDNS service
Syntax
update dns {override}
Parameters
dns {override}
Configures DDNS parameters
  • override – Optional. Enables DDNS updates on an onboard DHCP server
Usage Guidelines
A DHCP client cannot perform updates for RR‘s A, TXT and PTR resource records. Use update (dns)(override) to enable the internal DHCP server to send DDNS updates for resource records. The DHCP server can override the client, even if the client is configured to perform the updates.
In the DHCP server‘s DHCP pool, FQDN is configured as the DDNS domain name. This is used internally in DHCP packets between the DHCP server and the DNS server.
rfs4000-229D58(config-dhcp-policy-test-pool-testPool)#update dns override
rfs4000-229D58(config-dhcp-policy-test-pool-testPool)#show context
 dhcp-pool testPool
  address 192.168.13.4 class dhcpclass1
  update dns override
  ddns server 192.168.13.9
  ddns multiple-user-class
  excluded-address range 192.168.13.25 192.168.13.28
  netbios-node-type b-node
  dns-server 192.168.13.19
  netbios-name-server 192.168.13.25
  option option1 157.235.208.80
  respond-via-unicast
  static-route 192.168.13.0/24 192.168.13.7
Related Commands
no
Removes dynamic DNS service control
