radio-resource-measurement
Enables support for 802.11k radio
resource measurement capabilities (IEEE 802.11k) on this WLAN. 802.11k improves how traffic
is distributed. In a WLAN, devices normally connect to the access point with the strongest
signal. Depending on the number and location of clients, this arrangement can lead to
excessive demand on one access point and under utilization of others, resulting in
degradation of overall network performance. With 802.11k, if the access point with the
strongest signal is loaded to its capacity, a client connects to an under-utilized access
point. Even if the signal is weaker, the overall throughput is greater since it is an
efficient use of network resources. This feature is enabled by default.
- Access Points: AP5010, AP310i/e, AP410i/e, AP505i, AP510i, AP510e, AP560i, AP6522, AP6562, AP7161, AP7502,
AP8533.
- Service Platforms:
Syntax
radio-resource-measurement {tpc-report|neighbor-report {hybrid}}
Parameters
| radio-resource-measurement |
Enables support for 802.11k radio resource measurement capabilities |
| channel-report |
Optional. Includes the channel-report element in beacons and probe
responses |
| neighbor-report {hybrid} |
Optional. Enables responding to neighbor-report
requests
- hybrid – Optional. Uses the hybrid model of smart-rf neighbors and
roaming frequency to neighbors
| tpc-report |
Optional. Includes the tpc-report element in beacons and probe
responses |
ap505-13403B(config-wlan-test)#radio-resource-measurement neighbor-report hybrid
ap505-13403B(config-wlan-test)#show context
wlan test
ssid test
vlan 1
bridging-mode local
encryption-type gcmp256
authentication-type eap
dynamic-vlan-assignment allowed-vlans 2-4
protected-mgmt-frames mandatory
protected-mgmt-frames sa-query attempts 1
use aaa-policy test
http-analyze syslog host 10.234.160.4 port 21 proxy-mode through-controller
controller-assisted-mobility
opendns device-id 0014AADF8EDC6C59
dpi metadata http
Related Commands
| no (wlan-config-mode) |
Disables support for 802.11k radio resource measurement capabilities
(IEEE 802.11k) on this WLAN |
