Configures the security mode for this meshpoint
security-mode [eap|none|psk]
security-mode |
Configures the security mode for this meshpoint |
eap | Uses 802.1X/EAP as the security mode. When using this option, use the wpa2 command to specify the EAP authentication type and related parameters. |
none |
No security is configured for this meshpoint |
psk |
Uses PSK (Pre Shared Key as the security mode. When using this option, use the wpa2 command to enter a 64 character HEX or an 8-63 ASCII character passphrase used for authentication on the mesh point. |
The following example shows root meshpoint configuration with PSK authentication enabled:
nx9500-6C8809(config-meshpoint-test)#security-mode psk
nx9500-6C8809(config-meshpoint-test)#show context meshpoint test description "This is an example of a meshpoint description" meshid TestingMeshPoint beacon-format mesh-point control-vlan 1 allowed-vlans 1,10-16,18-23 neighbor inactivity-timeout 300 data-rates 2.4GHz bgn data-rates 5GHz an security-mode psk root nx9500-6C8809(config-meshpoint-test)#
The following example shows root meshpoint configuration with EAP authentication enabled:
nx9500-6C8809(config-meshpoint-root)#show context meshpoint root meshid test beacon-format mesh-point control-vlan 101 allowed-vlans 101,103 use aaa-policy test security-mode eap root nx9500-6C8809(config-meshpoint-test)#
no (meshpoint-config) | Resets the security configuration for this meshpoint to “none”. This indicates that no security is configured for this meshpoint. |
