Enter a question mark (?) at the system prompt to display a list of commands available for each mode. Obtain a list of arguments and keywords for any command using the CLI context-sensitive help.
Use the following commands to obtain help specific to a command mode, command name, keyword or argument:
Command |
Description |
(prompt)# help |
Displays a brief description of the help system |
(prompt)# abbreviated-command-entry? |
Lists commands in the current mode that begin with a particular character string |
(prompt)# abbreviated-command-entry<TAB> |
Completes a partial command name |
(prompt)# ? |
Lists all commands available in the command mode |
(prompt)# command ? |
Lists the available syntax options (arguments and keywords) for the command |
(prompt)# command keyword ? |
Lists the next available syntax option for the command |
The system prompt varies depending on the configuration mode.
Enter Ctrl + V to use ? as a regular character and not as a character used for displaying context sensitive help. This is required when the user has to enter a URL that ends with a ?
The escape character used through out the CLI is "\". To enter a "\" use "\\" instead.When using context-sensitive help, the space (or lack of a space) before the question mark (?) is significant. To obtain a list of commands that begin with a particular sequence, enter the characters followed by a question mark (?). Do not include a space. This form of help is called word help, because it completes a word.
nx9500-6C8809#service? service Service Commands nx9500-6C8809#
ap505-13403B#se? self Config context of the device currently logged into service Service Commands set-personality Change personality on next reload ap505-13403B#
Enter a question mark (?) (in place of a keyword or argument) to list keywords or arguments. Include a space before the "?". This form of help is called command syntax help. It shows the keywords or arguments available based on the command/keyword and argument already entered.
nx9500-6C8809#service ?
block-adopter-config-update Block configuration updates from the
adopter
bluetooth Bluetooth service commands
clear Reset functions
cli-tables-skin Choose a formatting layout/skin for CLI
tabular outputs (EXPERIMENTAL-Applies only
to certain commands)
cluster Cluster Protocol
copy Copy files or directories
database Database Commands
delete Delete sessions
delete-offline-aps Delete Access Points that are configured
but offline
eguest Guest commands
force-send-config Resend configuration to the device
force-update-vm-stats Force VM statistics to be pushed up to the
NOC
guest-registration Guest registration
load-balancing Wireless load-balancing service commands
load-ssh-authorized-keys Load Ssh authorized keys
locator Enable leds flashing on the device
mint MiNT protocol
nsight Nsight
pktcap Start packet capture
pm Process Monitor
radio Radio parameters
radius Radius test
request-full-config-from-adopter Request full configuration from the
adopter
restore Restore from a backup
set Set global options
show Show running system information
signal Send a signal to a process
smart-rf Smart-RF Management Commands
snmp Snmp
snmpv3 Snmpv3
ssm Command related to ssm
start-shell Provide shell access
syslog Syslog service
trace Trace a process for system calls and
signals
troubleshoot Troubleshooting
wireless Wireless service commands
nx9500-6C8809#
It is possible to abbreviate commands and keywords to allow a unique abbreviation. For example, "configure terminal" can be abbreviated as config t. Since the abbreviated command is unique, the wireless controller accepts the abbreviation and executes the command.
Enter the help command (available in any command mode) to provide the following description:
ap505-13403B>help When using the CLI, help is provided at the command line when typing '?'. If no help is available, the help content will be empty. Backup until entering a '?' shows the help content. There are two styles of help provided: 1. Full help. Available when entering a command argument (e.g. 'show ?'). This will describe each possible argument. 2. Partial help. Available when an abbreviated argument is entered. This will display which arguments match the input (e.g. 'show ve?'). ap505-13403B>
