interface-config-vlan-instance
Associates an IP (IPv4 and IPv6) access list, bonjour-gw-discovery policy, and an IPv6-router-advertisement policy with this VLAN interface
use [bonjour-gw-discovery-policy <POLICY-NAME>|ip-access-list in <IP-ACL-NAME>| ipv6-access-list in <IPv6-ACL-NAME>|ipv6-router-advertisement-policy <POLICY-NAME>| url-filter <URL-FILTER-NAME>]
bonjour-gw-discovery-policy <POLICY-NAME> | Uses an existing Bonjour GW Discovery
policy with this VLAN interface. When associated, the
Bonjour GW Discovery policy is applied for the Bonjour
requests coming over the VLAN interface.
ip-access-list in <IP-ACCESS-LIST-NAME> | Uses a specified IPv4 access list with this interface
ipv6-access-list in <IPv6-ACCESS-LIST-NAME> | Uses a specified IPv6 access list with this interface
ipv6-router-advertisement-policy <POLICY-NAME> | Uses an existing IPv6 router advertisement policy with this VLAN interface.
url-filter <URL-FILTER-NAME> | Enforces URL filtering on this VLAN interface by associating a URL filter
nx9500-6C8809(config-profile-default-nx5500-if-vlan8)#use ip-access-list in test nx9500-6C8809(config-profile-default-nx5500-if-vlan8)#show context interface vlan8 ip address 10.0.0.1/8 use ip-access-list in test ip helper-address 172.16.10.3 nx9500-6C8809(config-profile-default-nx5500-if-vlan8)#
no | Disables or reverts interface VLAN settings to their default |
