data-rates
      Configuration the 802.11 rates
         supported on this WLAN
            - Access Points: AP5010, AP310i/e, AP410i/e, AP505i, AP510i, AP510e, AP560i, AP6522, AP6562, AP7161, AP7502,
               AP8533.
            - Service Platforms:
      Syntax
         data-rates [2.4GHz|5GHz|6GHz]
         data-rates 2.4GHz [b-only|bg|bgn|custom|default|g-only|gn]
         data-rates 2.4GHz custom [1|11|12|18|2|24|36|48|5.5|54|6|9|basic-1|basic-11|basic-12|
basic-18|basic-2|basic-24|basic-36|basic-48|basic-5.5|basic-54|basic-6|basic-9|
basic-mcs-1s|mcs-1s|mcs-2s|mcs-3s|basic-mcs-1s|basic-mcs0-7|mcs-1s|mcs-2s|mcs-3s|
mcs0-15|mcs0-23|mcs0-7|mcs16-23|mcs8-15|mcs8-23]
         data-rates 5GHz [a-only|an|custom|default]
         data-rates 5GHz custom [12|18|24|36|48|54|6|9|basic-1|basic-11|basic-12|basic-18|
basic-2|basic-24|basic-36|basic-48|basic-5.5|basic-54|basic-6|basic-9|basic-mcs-1s|
basic-mcs0-7|mcs-1s|mcs2s|mcs3s|mcs4s|mcs0-15|mcs0-23|mcs0-7|mcs16-23|mcs8-15|mcs8-23]
         data-rates 6GHz (ax|default)
data-rates 6GHz custom {1s|2s|3s|4s|LIST|basic-6|basic-9|basic-12|basic-18|basic-24|basic-36|
basic-48|basic-54}
data-rates 6GHz custom {6|9|12|18|24|36|48|54|basic-1|basic-2|basic-5.5|basic-6|basic-9|basic-11|
basic-12|basic-18|basic-24|basic-36|basic-48|basic-54|mcs}
      Parameters
         data-rates 2.4GHz [b-only|bg|bgn|default|g-only|gn]
                     | data-rates |
                     Specifies the 802.11 rates supported when mapped to a 2.4 GHz
                        radio |
                     | b-only |
                     Uses rates that support only 11b clients |
                     | bg |
                     Uses rates that support both 11b and 11g clients |
                     | bgn |
                     Uses rates that support 11b, 11g and 11n clients |
                     | default |
                     Uses the default rates configured for a 2.4 GHz radio |
                     | g-only |
                     Uses rates that support operation in 11g only |
                     | gn |
                     Uses rates that support 11g and 11n clients |
         data-rates 5GHz [a-only|an|default]
                     | data-rates |
                     Specifies the 802.11 rates supported when mapped to a 5.0 GHz
                        radio |
                     | a-only |
                     Uses rates that support operation in 11a only |
                     | an |
                     Uses rates that support 11a and 11n clients |
                     | default |
                     Uses default rates configured for a 5.0 GHz |
                     | data-rates |
                     Specifies the data rates supported when mapped to a 6.0 GHz
                        radio |
                     | ax |
                     Uses rates that support operation in 11ax only |
                     | default |
                     Uses default rates configured for a 6.0 GHz |
basic-12|basic-18|basic-2|basic-24|basic-36|basic-48|basic-5.5|basic-54|basic-6|
basic-9|basic-mcs-1s|mcs-1s|mcs-2s|mcs-3s|basic-mcs-1s|basic-mcs0-7|mcs-1s|mcs-2s|
mcs-3s|mcs0-15|mcs0-23|mcs0-7|mcs16-23|mcs8-15|mcs8-23]
                     | data-rates [2.4GHz|5GHz|6GHz] |
                     Specifies the 802.11 rates supported when mapped to a 2.4 GHz, 5.0 GHz,
                        or |6GHz radio |
                     | custom |
                     Configures a data rates list by specifying each rate individually. Use
                        'basic-' prefix before a rate to indicate it is used as a basic rate (For
                        example, 'data-rates custom basic-1 basic-2 5.5 11'). The data-rates for
                           2.4 GHz and 5.0 GHz channels are the same with a few exceptions. The 2.4
                           GHz channel has a few extra data rates: 1, 11, 2, and 5.5.
                     | 1,11,2,5.5 |
                     The following data rates are specific to the 2.4 GHz channel:
                           - 1 – 1-Mbps
                           - 11 – 11-Mbps
                           - 2 – 2-Mbps
                           - 5.5 – 5.5-Mbps
                     | 12,18,24,36,48,54,6,9, basic-1,basic-11, basic-12,basic-18, basic-2,
                        basic-36,basic-48, basic-5.5, basic-54,basic-6, basic-9,
                        basic-mcs0-7,mcs0-15, mcs0-7,mcs8-15 |
                     The following data rates are common to both the 2.4 GHz and 5.0 GHz
                           channels:
                           - 12 – 12 Mbps
                           - 18 – 18-Mbps
                           - 24 – 24 Mbps
                           - 36 – 36-Mbps
                           - 48 – 48-Mbps
                           - 54 – 54-Mbps
                           - 6 – 6-Mbps
                           - 9 – 9-Mbps
                           - basic-1 – basic
                              1-Mbps
                           - basic-11 – basic
                              11-Mbps
                           - basic-12 – basic
                              12-Mbps
                           - basic-18 – basic
                              18-Mbps
                           - basic-2 – basic
                              2-Mbps
                           - basic-36 – basic
                              36-Mbps
                           - basic-48 – basic
                              48-Mbps
                           - basic-5.5 – basic
                              5.5-Mbps
                           - basic-54 – basic
                              54-Mbps
                           - basic-6 – basic
                              6-Mbps
                           - basic-9 – basic
                              9-Mbps
                           - basic-mcs-1s –
                              Modulation and coding scheme data rates for 1 Spatial Stream
                           - mcs-1s – Applicable to
                              1-spatial stream data rates
                           - mcs-2s – Applicable to
                              2-spatial stream data rates
                           - mcs-3s – Applicable to
                              3-spatial stream data rates
         nx9500-6C8809(config-wlan-test)#data-rates 2.4GHz gn
         nx9500-6C8809(config-wlan-test)#show context
wlan test
 ssid test
 bridging-mode local
 encryption-type none
 authentication-type eap
 accounting syslog host 172.16.10.4 port 2
 client-load-balancing probe-req-intvl 5ghz 5
 client-load-balancing band-discovery-intvl 2
 captive-portal-enforcement fall-back
 acl exceed-rate wireless-client-denied-traffic 20 disassociate
 broadcast-dhcp validate-offer
