router-id
Specifies the OSPF router ID. This ID must be established in every OSPF instance. If not explicitly configured, the highest logical IP address is duplicated as the router identifier. However, since the router identifier is not an IP address, it does not have to be a part of any routable subnet in the network.
Syntax
router-id <IP>
Parameters
router-id <IP>
<IP> Identifies the OSPF router by its IP address
  • <IP> – Specify the router ID in the IP <A.B.C.D> format
nx9500-6C8809(config-profile default-ap8533-router-ospf)#router-id 172.16.10.8
Reload, or execute "clear ip ospf process" command, for this to take effect
Related Commands
no (router-mode-config-command) Removes the configured OSPF router ID
