interface-config-radio-instance
Defines the radio‘s location (whether the radio is deployed indoors or outdoors). The radio‘s placement should depend on the country of operation selected and its regulatory domain requirements for radio emissions.
placement [indoor|outdoor]
placement | Defines the radio‘s location |
indoor | Radio is deployed indoors (uses indoor regulatory rules). This is the default setting. |
outdoor | Radio is deployed outdoors (uses outdoor regulatory rules) |
nx9500-6C8809(config-profile-510TestProfile-if-radio1)#placement outdoor nx9500-6C8809(config-profile-510TestProfile-if-radio1)#show context interface radio1 data-rates b-only placement outdoor mesh client off-channel-scan channel-list 2.4GHz 1 guard-interval long aggregation ampdu tx-only aeroscout forward ekahau forward ip 172.16.10.1 port 3 non-unicast tx-rate bss 1 dynamic-all non-unicast tx-rate bss 2 highest-basic non-unicast tx-rate bss 3 highest-basic non-unicast tx-rate bss 4 highest-basic non-unicast tx-rate bss 5 highest-basic non-unicast tx-rate bss 6 highest-basic non-unicast tx-rate bss 7 highest-basic non-unicast tx-rate bss 8 highest-basic non-unicast tx-rate bss 9 highest-basic non-unicast tx-rate bss 10 highest-basic non-unicast tx-rate bss 11 highest-basic non-unicast tx-rate bss 12 highest-basic non-unicast tx-rate bss 13 highest-basic non-unicast tx-rate bss 14 highest-basic --More-- nx9500-6C8809(config-profile-510TestProfile-if-radio1)#
no (radio-interface-config-command) | Resets a radio‘s deployment location |
