Enables dynamic channel switching for Smart RF radios. This command allows you to configure an override list of channels that Smart RF can use for channel compensations on 2.4 GHz, 5.0 GHz, or 6.0 GHz radios.
When a radio fails or is faulty, a Smart RF policy provides automatic recovery by instructing neighboring access points to increase their transmit power to compensate for the coverage loss. Once correct access point placement has been established, Smart-RF can optionally be leveraged for automatic detector radio selection. Smart-RF uses detector radios to monitor RF events and can ensure availability of adequate detector coverage.
override-smartrf channel-list [2.4GHz|5GHZ|6GHZ] <CHANNEL-LIST>
| override-smartrf | Enables dynamic channel switching for Smart RF radios |
| channel-list | Configures a list of channels for 2.4 GHz, 5.0 GHz, or 6.0 GHz Smart RF radios |
| 2.4GHz <CHANNEL-LIST> | Selects the 2.4 GHz Smart RF radio channels
| 5GHz <CHANNEL-LIST> | Selects the 5.0 GHz Smart RF radio channels
| 6GHz <CHANNEL-LIST> | Selects the 6.0 GHz Smart RF radio channels
nx9500-6C8809(config-rf-domain-default)#override-smartrf channel-list 2.4GHz 1,2,3
         nx9500-6C8809(config-rf-domain-default)#show context rf-domain default contact Bob+14082778691 country-code us override-smartrf channel-list 2.4GHz 1,2,3 layout area Ecospace floor Floor1 map-location www.firstfloor.com units meters nx9500-6C8809(config-rf-domain-default)#
| no (rf-domain-config-mode) | Removes the override-smartrf list of channels configured for 2.4 GHz, 5.0 GHz, or 6.0 GHz radios |
