Log on to the controller in config mode and follow the procedure below:
nx9500-6C8809(config-profile-default-ap505)#interface vlan 150 nx9500-6C8809(config-profile-default-ap505-if-vlan150)#ip address 192.168.150.20/24 nx9500-6C8809(config-profile-default-ap505-if-vlan150)#exit nx9500-6C8809(config-profile-default-ap505)#interface ge 1 nx9500-6C8809(config-profile-default-ap505-if-ge1)#switchport access vlan 150 nx9500-6C8809(config-profile-default-ap505-if-ge1)#commit write memory [OK] nx9500-6C8809(config-profile-default-ap505-if-ge1)#show interface vlan 150 Interface vlan150 is UP Hardware-type: vlan, Mode: Layer 3, Address: 00-15-70-81-70-1D Index: 6, Metric: 1, MTU: 1500 IP-Address: 192.168.150.20/24 input packets 0, bytes 0, dropped 0, multicast packets 0 input errors 0, length 0, overrun 0, CRC 0, frame 0, fifo 0, missed 0 output packets 2, bytes 140, dropped 0 output errors 0, aborted 0, carrier 0, fifo 0, heartbeat 0, window 0 collisions 0 IPv6 mode is disabled nx9500-6C8809(config-profile-default-ap505-if-ge1)#
