static-route (dhcpv4-pool-config)
Configures a static route for a DHCP pool. Static routes define a gateway for traffic intended for other networks. This gateway is always used when an IP address does not match any route in the network.
Syntax
static-route <IP/M> <IP>
Parameters
<IP/M>
Specifies the IP destination prefix (for example, 10.0.0.0/8)
<IP>
Specifies the gateway IP address
nx9500-6C8809(config-dhcp-policy-test-pool-testPool)#static-route 192.168.13.0/24 192.168.13.7
nx9500-6C8809(config-dhcp-policy-test-pool-testPool)#show context
 dhcp-pool testPool
  address 192.168.13.4 class dhcpclass1
  ddns server 192.168.13.9
  ddns multiple-user-class
  excluded-address range 192.168.13.25 192.168.13.28
  netbios-node-type b-node
  dns-server 192.168.13.19
  netbios-name-server 192.168.13.25
  option option1 157.235.208.80
  respond-via-unicast
Related Commands
no
Removes static route settings
