description (meshpoint-config)
Configures a brief description for this meshpoint
Syntax
description <DESCRIPTION>
Parameters
description
Configures a description for this meshpoint
<DESCRIPTION>
The text describing this meshpoint. Enter a 64 character maximum description about the mesh point that uniquely identifies it from other meshpoints.
nx9500-6C8809(config-meshpoint-test)#description "This is an example of a meshpoint description"
nx9500-6C8809(config-meshpoint-test)#show context
meshpoint test
 description "This is an example of a meshpoint description."
 meshid test
 beacon-format mesh-point
 control-vlan 25
 allowed-vlans 1,10-16,18-23
 data-rates 2.4GHz bgn
 data-rates 5GHz an
 security-mode none
 no root
Related Commands
no (meshpoint-config)
Removes the human friendly description provided for this meshpoint
