The L2TPv3 policy defines the control and encapsulation protocols needed for tunneling layer 2 frames between two IP nodes. This policy enables creation of L2TPv3 tunnels for transporting Ethernet frames between bridge VLANs and physical GE ports. L2TPv3 tunnels can be created between any vendor devices supporting L2TPv3 protocol.
l2tpv3 policy <L2TPV3-POLICY-NAME>
                         l2tpv3 policy <L2TPV3-POLICY-NAME>  |
                         Configures an L2TPV3 tunnel policy
nx9500-6C8809(config)#l2tpv3 policy L2TPV3Policy1 nx9500-6C8809(config-l2tpv3-policy-L2TPV3Policy1)#? L2tpv3 Policy Mode commands: cookie-size Size of the cookie field present in each l2tpv3 data message failover-delay Time interval for re-establishing the tunnel after the failover (RF-Domain manager/VRRP-master/Cluster-master failover) force-l2-path-recovery Enables force learning of servers, gateways etc., behind the l2tpv3 tunnel when the tunnel is established hello-interval Configure the time interval (in seconds) between l2tpv3 Hello keep-alive messages exchanged in l2tpv3 control connection no Negate a command or set its defaults reconnect-attempts Maximum number of attempts to reestablish the tunnel. reconnect-interval Time interval between the successive attempts to reestablish the l2tpv3 tunnel retry-attempts Configure the maximum number of retransmissions for signaling message retry-interval Time interval (in seconds) before the initiating a retransmission of any l2tpv3 signaling message rx-window-size Number of signaling messages that can be received without sending the acknowledgement tx-window-size Number of signaling messages that can be sent without receiving the acknowledgement clrscr Clears the display screen commit Commit all changes made in this session do Run commands from Exec mode end End current mode and change to EXEC mode exit End current mode and down to previous mode help Description of the interactive help system revert Revert changes service Service Commands show Show running system information write Write running configuration to memory or terminal nx9500-6C8809(config-l2tpv3-policy-L2TPV3Policy1)#
| no | Removes an existing L2TPV3 tunnel policy |
| mint-policy | Configures the global MiNT policy |
