sms-over-smtp
Configures an e-mail host server (for
example: smtp.gmail.com) along with sender related credentials and the recipient gateway
e-mail address to which the message is E-mailed. The gateway server converts the e-mail into
SMS and sends the message to the guest user‘s mobile device.When sending an e-mail, the
e-mail client interacts with a SMTP server to handle the content transmission. The SMTP
server on the host may have conversations with other SMTP servers to deliver the
e-mail.
- Service Platforms — NX 75XX, NX 95XX, NX 96XX, VX 9000
Syntax
sms-over-smtp [host|message|subject]
sms-over-smtp host [<IP/HOSTNAME>|<HOST-ALIAS-NAME>] sender <EMAIL-ADDRESS>
security [none|ssl|starttls] username <USER-NAME> password <PASSWORD> recipient <EMAIL-ADDRESS>
sms-over-smtp message <LINE>
sms-over-smtp subject <LINE>
Parameters
sms-over-smtp host [<IP/HOSTNAME>|<HOST-ALIAS-NAME>] sender <EMAIL-ADDRESS> security
sms-over-smtp |
Configures guest user SMS over SMTP notification
settings |
host [<IP/HOSTNAME>| <HOST-ALIAS-NAME>] |
Configures the SMS gateway server resource‘s IPv4
address or hostname used for guest management SMS over SMTP traffic, guest user
credential validation and pass code reception. Optionally you can use an existing
host alias to identify the SMS gateway server resource.
- <IP/HOSTNAME> – Specify the SMTP gateway server resource‘s IP address or
hostname.
- <HOST-ALIAS-NAME> – Specify the host alias name (should existing and
configured). Consider providing the host as an alias. A host alias is a
configuration item that maps the alias to a hostname. Once created, it can be
used across different configuration modes. Where ever used the alias is replaced
by the associated hostname.
sender <EMAIL-ADDRESS> |
Configures the sender‘s e-mail address. The sender here
is the guest user receiving the pass code. Guest users require this pass code for
registering their guest e-mail credentials using SMTP.
- <EMAIL-ADDRESS> – Specify the e-mail address (should not exceed 64
characters).
security [none|ssl|starttls] |
Configures the encryption protocol used by the SMTP
server when communicating the pass code
- none – No encryption used. Use if no additional user authentication is needed
beyond the required username and password combination.
- SSL – Uses SSL encryption. This is the default setting.
- STARTTLS – Uses STARTTLS encryption
username <USER-NAME> |
Configures a username unique to this SMTP guest
management configuration. After configuring the username, specify the associated
password. Ensure that the correct password is provided to receive the pass code
required for registering guest user credentials with SMTP.
- <USER-NAME> – Specify the username (should not exceed 64 characters).
password <PASSWORD> |
Configures the password associated with the specified
SMTP user name
- <PASSWORD> – Specify the password (should not exceed 64 characters).
recipient <EMAIL-ADDRESS> |
Configures the e-mail recipient's e-mail address
- <EMAIL-ADDRESS> – Specify the recipient‘s e-mail address (should not exceed
64 characters in length.
sms-over-smtp |
Configures guest user SMS over SMTP notification message
content |
message <LINE> |
Configures the content of the SMS over SMTP sent to the
guest user notifying the pass code (should not exceed 1024 characters)
- <LINE> – Specify the message content. When entering the message, use the
following tags:
GM-NAME – for the guest user‘s name
GM_PASSCODE – for
the pass code
CR-NL – to enter a new line
For example: Dear
GM_NAME, CR-NL your internet access pass code is GM_PASSCODE. CR-NL Use this
access code for internet access.
sms-over-smtp |
Configures guest user e-mail notification subject line content |
subject <LINE> |
Configures the subject line of the SMS over SMTP sent to the guest user
notifying the pass code (should not exceed 100 characters) |
nx9500-6C8809(config-guest-management-test3)#sms-over-smtp host test sender
bob@extremenetworks.com security ssl username bob password bob@123 recipient john@extremenetworks.com
nx9500-6C8809(config-guest-management-test3)#show context
guest-management test3
sms-over-smtp host test sender bob@extremenetworks.com security ssl username bob password bob@123 recipient john@extremenetworks.com
