passpoint-policy
The following table summarizes the Passpoint Policy configuration mode commands:
Table 1. Passpoint-Policy Config Mode Commands
Command
Description
3gpp
Configures a 3gpp (3rd Generation Partnership Project) PLMN (Public Land Mobile Network) ID
access-network-type
Configures the access network type element in this hotspot
connection-capability
Configures the connection capability element in this passpoint policy
domain-name
Configures the RF Domains to which this hotspot is applicable
hessid
Configures the HESSID (Homogeneous Extended Service Set Identifier) for a specified hotspot zone
internet
Advertises the availability of Internet access in this hotspot
ip-address-type
Advertises the IP address type used in this hotspot.
nai-realm
Configures a NAI (Network Access Identifier) realm name and enters its configuration mode
net-auth-type
Configures the network authentication type used in this hotspot
operator
Configures the operator friendly name for this hotspot
osuConfigures an OSU (online sign up) SSID/provider and enters its configuration mode
roam-consortium
Configures the list of Roaming Consortium OIs (Organization Identifiers) supported on this hotspot
venue
Configures the venue group and type for this passpoint policy
wan-metrics
Configures the WAN performance metrics for this hotspot
no
Removes or reverts passpoint policy configuration
The input parameter <HOSTNAME>, wherever used in syntaxes across this chapter, cannot include an underscore (_) character. In other words, the name of a device cannot contain an underscore.
For more information on common commands (clrscr, commit, help, revert, service, show, write, and exit), see Common Commands .
