no (l2tpv3-tunnel-config-mode-command)
Removes this L2TPv3 tunnel settings or reverts them to default value
Syntax
no [establishment-criteria|fast-failover|hostname|local-ip-address|mtu|peer <1-2>|preempt|router-id|session|use]
Parameters
no <PARAMETERS>
no <PARAMETERS> Negates or reverts a L2TPv3 tunnel settings to default, based on the parameters passed
The tunnel settings before the ‘no‘ command is executed:
nx9500-6C8809(config-profile default-nx5500-l2tpv3-tunnel-Tunnel1)#show context
 l2tpv3 tunnel Tunnel1
  local-ip-address 172.16.10.2
  mtu 1280
  hostname TunnelHost1
  establishment-criteria cluster-master
nx9500-6C8809(config-profile default-nx5500-l2tpv3-tunnel-Tunnel1)#no local-ip
-address
nx9500-6C8809(config-profile default-nx5500-l2tpv3-tunnel-Tunnel1)#no mtu
nx9500-6C8809(config-profile default-nx5500-l2tpv3-tunnel-Tunnel1)#no hostname
The tunnel settings after the ‘no‘ command is executed:
