Enables authentication of MAC addresses on the selected wired port. When enabled, this feature authenticates the MAC address of a device, connecting to this interface, with a RADIUS server. When successfully authenticated, packets from the source are processed. Since only one MAC address is supported per wired port, packets from all other sources are dropped.
For more information on enabling this feature, see mac-auth.
Enable port MAC authentication in conjunction with Wired 802.1x settings to configure a MAC authentication AAA policy.
This option is also available in the device configuration mode.
mac-auth
None
nx9500-6C8809(config-profile-testnx5500-if-ge1)#mac-auth nx9500-6C8809(config-profile-testnx5500-if-ge1)#show context interface ge1 mac-auth ip dhcp trust qos trust dscp qos trust 802.1p channel-group 1 nx9500-6C8809(config-profile-testnx5500-if-ge1)# nx9500-6C8809(config-profile-testnx5500-if-ge1)#mac-auth nx9500-6C8809(config-profile-testnx5500-if-ge1)#show context interface ge5 switchport mode access switchport access vlan 1 dot1x authenticator host-mode single-host dot1x authenticator guest-vlan 5 dot1x authenticator port-control auto mac-auth nx9500-6C8809(config-profile-testnx5500-if-ge1)#
no | Disables authentication of MAC addresses on the selected wired port |
