Configures the ExtremeLocation server‘s hostname on the AP. When configured, the access point uses a Websocket, to forward 802.11 frames and BLE beacons to the specified ExtremeLocation server.
Starting with WiNG 7.1.2, AP5XX APs will not use WIPS to collect WiFi packets and BLE (iBeacons and Eddystone) beacons. The information will be collected in the Collector Table and forwarded to the ExtremeLocation server from the Collector Table.
The AP's radio should be in the radio-share or sensor mode and the AP's BLE radio should be in the le-sensor mode.
location-server 1 ip <HOSTNAME> {port <1-65535>}
location-server 1 ip <HOSTNAMEL> | Identifies the ExtremeLocation server by its hostname
port <1-65535> | Optional. Configures the port where the ExtremeLocation server is
reachable.
nx9500-6C8809(config-device-94-9B-2C-13-40-38)#location-server 1 ip feeds.extremelocation.com port 200 nx9500-6C8809(config-device-94-9B-2C-13-40-38)#show context include-factory | include location-server location-server 1 ip test port feeds.extremelocation.com nx9500-6C8809(config-device-94-9B-2C-13-40-38)#
nx9500-6C8809(config-sensor-policy-ble)#rssi-interval-duration 35
nx9500-6C8809(config-device-94-9B-2C-13-40-38)#use sensor-policy ble
nx9500-6C8809(config-device-94-9B-2C-13-40-38)#location-tenantid 1234
no | Removes the ExtremeLocation server configuration. |
