database-policy global config
Creates a
database-policy and enters its configuration mode. After creating the
database-policy, use it on the database host. This enables the database.
If deploying a database replica-set, use this command to define the
replica set configurations. To enforce database authentication, enable
authentication on the database-policy, and configure the username and
password required to access the database. Note, this command is part of
a set of configurations that are required to enable authentication. For
more information on the entire set of configurations, see Example: Enabling Database Authentication.
Supported in the
following platforms:
- Service Platforms —
NX9500, NX9600, VX9000
Syntax
database-policy <DATABASE-POLICY-NAME>
Parameters
database-policy <DATABASE-POLICY-NAME> |
Specify the database policy name. If the policy with the specified name does
not exist, it is created. |
nx9500-6C8809(config)#database-policy test
nx9500-6C8809(config-database-policy-test)#?
Database Policy Mode commands:
authentication Database authentication
no Negate a command or set its defaults
replica-set Replica Set
shutdown Disable database server
clrscr Clears the display screen
commit Commit all changes made in this session
do Run commands from Exec mode
end End current mode and change to EXEC mode
exit End current mode and down to previous mode
help Description of the interactive help system
revert Revert changes
service Service Commands
show Show running system information
write Write running configuration to memory or terminal
Related
Commands
no |
Removes an existing database-policy |
database-client-policy global-config |
Documents database-client policy configuration commands.
The database-client-policy configures the IP address or hostname
of the database host, and is used on the EGuest server‘s device
context. |
use (profile/device-config-mode-commands) |
Uses a database-client-policy in the VX9000's device or
profile context |
database |
Drops or repairs a database. Also provides database keyfile
management capabilities. If enforcing authenticated access to
the database, use this command to generate, export, import, and
zerzoise the keyfile. |
