Configures the VLAN that is assigned to this captive portal‘s users upon successful authentication
post-authentication-vlan [<1-4096>|<VLAN-ALIAS>]
                         post-authentication-vlan [<1-4096>|<VLAN-ALIAS>]  |
                         Configures the post authentication VLAN. The VLAN specified here is assigned to this captive portal‘s users after they have authenticated and logged on to the network. Provide the VLAN ID, or use an existing VLAN alias to identify the post authentication VLAN.
rfs4000-229D58(config-captive-portal-test)#post-authentication-vlan 1
         rfs4000-229D58(config-captive-portal-test)#show context captive-portal test post-authentication-vlan 1 rfs4000-229D58(config-captive-portal-test)#
                         Removes the post authentication RADIUS VLAN assigned to this captive portal's users  |
