Configures the selected GE port‘s LACP (Link Aggregation Control Protocol) port-priority value. If LACP is enabled, and the selected port is a member of a LAG (link aggregation group), use this command to configure the port‘s priority within the LAG.
As per the IEEE 802.3ad standard, LACP enables aggregation of multiple physical links to form a single logical channel. Each aggregated group of physical links is a LAG. When enabled, LACP dynamically determines if link aggregation is possible between two peers, and automatically configures the aggregation. LACP also allows the switch to dynamically reconfigure the LAGs. The LAG is enabled only when LACP detects that the remote device is also using LACP and is able to join the LAG.
Enabling LACP provides automatic recovery in case one or more of the aggregated physical links fail.
lacp port-priority <1-65535>
| lacp port-priority <1-65535> | Configures the
                        selected GE port‘s port-priority value. The selected port‘s actual priority
                        within the LAG is determined by the port-priority value specified here along
                        with the port‘s number. Higher the value, lower is the priority. Use this
                        option to manipulate a port‘s priority. For example, in a LAG having five
                        physical ports, four active and one standby, manually increasing the standby
                        port‘s priority ensures that if one of the active port fails, the standby
                        port is included in the LAG during re-negotiation.
nx9500-6C8809(config-profile-testnx9000-if-ge1)#lacp port-priority 2 nx9500-6C8809(config-profile-testnx9000-if-ge1)#show context interface ge1 lacp port-priority 2 nx9500-6C8809(config-profile-testnx9000-if-ge1)#
| no | Removes the selected GE port‘s configured port-priority value |
