monitoring-interval
Configures the interval, in seconds, at which clients are monitored to determine if their RSSI value is below the specified handoff-threshold value
Syntax
monitoring-interval <1-60>
Parameters
Specifies the interval, in seconds, at which clients are monitored to determine if their RSSI is below the specified handoff-threshold
  • <1-60> – Specify the duration from 1 - 60 seconds. The default is 5 seconds.
nx9500-6C8809(config-roaming-assist-policy-test)#monitoring-interval 40
nx9500-6C8809(config-roaming-assist-policy-test)#show context
roaming-assist-policy test
 aggressiveness medium-high
 handoff-count 5
 detection-threshold -90
 handoff-threshold -75
 action log
 disassoc-time 7
Related Commands
no Removes the configured monitoring interval details
