mac-auth
bridge
Enables source MAC authentication for Extended VLAN and tunneled traffic (MiNT and L2TPv3) on this bridge VLAN. When enabled, it provides fast path authentications of clients, whose captive portal session has expired.
Syntax
mac-auth {attempts <1-5>|throttle <0-255>}
Parameters
mac-auth {attempts <1-5>|throttle <0-255>}]
mac-auth Enables MAC Authentication
attempts <1-5> Optional. Configures the maximum number of retries allowed for MAC authentication requests.
  • <1-5> – Specify the maximum allowed authentication retries from 1 - 5. The default is 3.
throttle <0-255> Optional. Configures the throttle value for MAC authentication requests
  • <0-255> – Specify the MAC authentication request throttle value from 0 -255. The default is 64.
Usage Guidelines : Applying AAA Policy for MAC Authentication
To enable MAC authentication,
Usage Guidelines: Enabling Fall-back Captive Portal Authentication
To enable fall-back captive-portal authentication on the bridge VLAN,
nx9500-6C8809(config-profile testNX9000-bridge-vlan-20)#mac-auth attempts 2
nx9500-6C8809(config-profile testNX9000-bridge-vlan-20)#mac-auth throttle 80
nx9500-6C8809(config-profile testNX9000-bridge-vlan-20)#show context
 bridge vlan 20
  mac-auth attempts 2
  ip igmp snooping
  ip igmp snooping querier
  ipv6 mld snooping
  ipv6 mld snooping querier
Related Commands
no Disables MAC authentication for Extended VLAN and Tunneled traffic on this bridge VLAN
